replace incoming number from +44 to 0
DavidTaylor7901
On a 8841 with multi platform firmware, when we get a call it displays as +44 leaving off the 0, is it possible to use the caller ID map to switch any number that comes in on a +44 to auto switch to 0
bijpraka
You can use the dial plan to substitute +44 with 0
If i do this on caller id map if i set the string as (<+44:0>xxxxxxxxxx) would that replace the incoming number from +44 to 0?
Dave
