Highlighted
Replication between Publisher and Subscriber Failed
Dears,
Replication between Publisher and Subscriber Failed.I have given below command it to subscriber and publisher but output is negative.
 utils dbreplication stop -----------------on all the subscribers.
 utils dbreplication stop  ----------------on the publisher.
 utils dbreplication dropadmindb ----------------------on all the subscribers.
 utils dbreplication dropadmindb  ------------------- on the publisher.
 utils dbreplication reset all -------------------------- on the publisher.
I attached below output file. Please find this attachment. I need help.
cisco ucs 240 server
Esxi 5.5
cucm 11
kafi
3 REPLIES 3
VIP Advisor
From unified reporting, can you share a diagnostic report about db replication.
Please find below attachment.
 I can see that ping time is 65 to one subscriber and all servers has different subnet. Make sure about the connection between all nodes.
Also there is an issue with hosts file you may need TAC case to access the database and hosts file to verify what is wrong.
Did you upgrade the servers? if yes did you completed all servers?
Muaaz
Content for Community-Ad
July's Community Spotlight Awards
