03-01-2014 11:05 AM - edited 03-16-2019 09:58 PM
Hi Support Community
We are using CUCM 8.6.2 and we have 3000 user device profiles. Issue is we only have 2500 staff so clearly some house keeping needs to be done.
You can run a report that shows you logged in extension mobility users and date/time they logged in but what im looking for is some way of getting the information which shows the last date UDP profiles were used, im hoping somebody maybe able to point me in the right direction of a database command i can run, something along the lines of show UDP profiles that have not been accessed for 6 months etc
I have done a bit of reading online and cannot find anything apart from a few similar questions that dont seem to have a solution.
Thanks, Carl Ratcliffe
Solved! Go to Solution.
03-02-2014 11:36 AM
Hi Carl.
This query reports all users with udp profile in the ststem
Carlo
03-01-2014 12:08 PM
I think the only thing you could do would be to parse thru the EM traces and them crosscheck against the configured UDPs.
03-01-2014 12:11 PM
Hi Jaime
Yes i was thinking the same was just hoping somebody was going to have another solution before we settle for this method.
Thanks, Carl
03-02-2014 05:12 AM
Hi Carl.
You can run this query to verify last login per user
run sql select eu.userid, emd.logintime, emd.loginduration, emd.datetimestamp from extensionmobilitydynamic emd inner join enduser eu on emd.fkenduser_lastlogin=eu.pkid
Carlo
03-02-2014 07:41 AM
Thanks Carlo
Do you know if there is anyway of running a similar query that would say bring back users who's last login time was over 6 months ago.
03-02-2014 09:37 AM
Hi Carl.
The query gives you the timestamp of last time that the user logged in, if you add "order by emd.datetimestamp desc" the last entry would be the erliest login seen by CUCM it's in universal format and you can convert here http://www.onlineconversion.com/unix_time.htm
Carlo
Please rate all helpful posts
"The more you help the more you learn"
03-02-2014 11:08 AM
Hi Carlo and thanks for your response.
Isnt this query per user though ? What i was looking for was a generic query which will bring me back all UDP on the system in 1 query that havent been accessed for over 6 months. Then these users only will be cross referenced against leavers lists etc raher then having to run a uery for each user.
03-14-2014 06:29 AM
Carl,
This query shows the login report for the whole system, an example shown below
dmin:run sql select eu.userid, emd.logintime, emd.loginduration, emd.datetimestamp from extensionmobilitydynamic emd inner join enduser eu on emd.fkenduser_lastlogin=eu.pkid
userid logintime loginduration datetimestamp
Patthew.Bullins2 NULL NULL 1344853306
Patthew.Bullins2 1345545975 0 1345545975
Dris.K.Rodger NULL NULL 1335772564
Dris.K.Rodger 1336038675 0 1336038675
CO006 1322570852 0 1322570851
Agus.Dallagher 1323181680 0 1323181679
Shetina.Bands 1339434053 0 1339434052
03-17-2014 09:55 AM
Hi Ayodeji
Thanks for the response. The query is really good for seeing who is logged into EM and for how long but what i am looking for is who isnt logged in and when the last time they did log in.
So for example we have 3000 user device profiles but only 2500 staff. We have checked with our IPT team and it seems they are not informed about leavers therefore user device profiles of leavers have been left on the system. We want to delete these profiles so what we want to do is narrow the search down by having a query which brings back user device profiles not logged into EM say for at least 3 months. We can then use this narrowed down search to delete rather than go through all 3000 profiles.
Is there also a query that can be run which will tell us any user device profiles that are not associated to a user ?
03-14-2014 05:59 AM
Hi Carlo Poggiarelli.
You told to run this query:
Where have I run this query?
03-02-2014 11:36 AM
Hi Carl.
Carlo
03-02-2014 11:39 AM
Excellent, Thanks Carlo i will give this a try hen im back in the office tomorrow.
