Report of all calls to and from an extension CUCM 8.6
James Gladwell
PBX operator supervisor is asking for a report of all calls made from and received by a certain extension, they think an employee is abusing the phone.
Is there a log by default or is it something that I need to configure and then run a report on?
5 Replies 5
Jaime Valencia
Assuming you have CDR enabled, you can use CAR, if you don't have CDR enabled, your best bet would be to review CUCM logs.
java
if this helps, please rate
What do all those acronyms mean? :)
Call Detail Records
CDR Analysis and Reporting
If you're and end user, I'd suggest you to reach your CUCM admin for this task.
java
Nope, I am a CUCM "admin" now.  Picking my way through this and trying not to cause too much damage in the process.
James Gladwell
