Community Helping Community
554
Beginner
Request calrification on T1/E1/PRI
Dear Experts,
1)I have configured many E1 implementations so far. But today while preparing for my CCNP i got this confusion. We use an E1 card for connecting a PRI. But i read E1 and PRI or different!
2)DS0 means Cas, Pri means CCS signalling, then for T1, E1 what we would use?
3)In a T1 we get total 24 channels, if we use CAS then we get 24 channels, and with CCS we get 23 channels. But for E1, when we use CCS we get only 30 B Channels and 1D channel, where as the 32nd Channel?
Kindly consider this as my learning and help me!
1 ACCEPTED SOLUTION
Collaborator
Re: Request calrification on T1/E1/PRI
Hi Sampath,
Pls find the reply inline:
T1 and E1 are classified based on the geographical locations. In countries like U.S, we get only T1 lines from them and in places like Europe, India we have E1 lines. If you simply tell E1 then you mean a E1 CAS and if you configure the E1 line with CCS, its called E1 PRI.
With T1 PRI, you get 23 B channels for data/voice and one D channel for control
With E1 PRI its a bit different, there is a one separate channel for control and one for signalling,
So with E1 PRI, you get 30 B channels for data/voice, 1 for signaling and 1 for control messages.
Rajan
Pls rate all useful posts by clicking the stars below
6 REPLIES 6
Rising star
To clarify things:
ISDN runs on top of the T1/E1 circuits. There are two types of signaling:
- CCS : Common channel signaling (it uses a dedicated DS0 channel for the signaling)
- CAS : Channel Associated Signaling (it uses the data channel for signaling)
Now, PRI is an interface standard used on ISDN in order to carry multiple DS0 channels.
With this in mind:
- E1 PRI with CCS = 30 B channels and 1 D  channel
- T1 PRI with CCS = 23 B channels and 1 D channel
- E1 PRI with CAS = 31 B Channels
- T1 PRI with CAS = 24 B Channels
This should also help you: VoIP with Common Channel Signaling (CCS)
Georgios
Please rate if you find this helpful.
Beginner
So on a T1 PRI, you get 23 B channels for data/voice and one D channel for control.
If there are 46 PRI channels needed does that mean 2xT1 channelized ports are needed for the device?
Thanks in advance!
Ton
Highlighted
Collaborator
Hi Ton,
yes, that is correct. YOu need 2XT1 ports to terminate two T1 connections to get 43 B channels
Rajan
Beginner
Hi Rajan,
Did you mean 46 B channels? If it's 43 then additional T1 would be needed.
Thanks in advance!
Ton
Collaborator
Hi Ton,
My bad, yes 2 T1 PRI connections can provide 46 channels in total.
But why you need additional T1 for 43 ? 2 would be more than enough
Rajan
Collaborator
Hi Sampath,
Rajan
Content for Community-Ad
FusionCharts will render here
