07-12-2011 05:23 AM - edited 03-16-2019 05:54 AM
cucm version : 8.0.3.10000-8 , Windows versiyon: microsfot link 2010
I want to deploy cucimoc for microsoft office communicator. I want to that I need cisco presence server or dont need .
or
If ı just install cucm with microsoft link 2010 (without cucimoc). What will be my requirements.( forexmple Presence server ... )
Solved! Go to Solution.
07-12-2011 07:30 AM
CUCILync does not utilize the CUP server. It is intended to provide the Cisco UC services you do have (e.g. Phone, voicemail, etc) with the MOC client.
Without CUCILync your integration options are a SIP trunk for call forking and/or the CUP server for CSTA gateway of presence information.
07-12-2011 07:30 AM
07-18-2011 03:12 AM
Hi Jonathan,
You mean If I want to use cucimoc with for ip phones with microsoft office communicator I dont need cisco presence server right?
and
If I want to use cucm integrated with linc I should use sip trunk for call forking with CUP server ?
07-18-2011 03:42 AM
CUCIMOC/Lync does not require a CUP server.
There are a few different options. Here are the documents for all three; read them and decide which makes the most sense in your environment.
07-25-2011 01:10 AM
Thank you very much Jonathan,
is there any document for Lynch Server 2010 with cucm as well ?
