Reroute Call in Router
jmaduncan
Hello all, I have a Call Manager 4.2 and a 2811 router connected to an ISDN simulator now and calls are routing fine but once they hit simulator, obviously, the call busies out. What I want to know is if there is a way to reroute the call instead of to the ISDN Simulator but instead reroute it in the router to a phone back on the Call Manager system?
Many Thanks
8 Replies 8
alessandro.dona
Level 3
Level 3
It would be a Voip-to-Voip(hair-pinning) call i know it is not allowed( a call from a voip dial peer must match an outbound pots dialpeer) but maybe there is a way to avoid this restriction!
From this link
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010ae1c.shtml
i red
Note: Hair-Pinning is the name given to calls that originate and terminate on the same router/gateway. On POTS-to-POTS Hair-Pinning calls, the router/gateway matches an inbound POTS dial-peer and an outbound POTS dial-peer to terminate the call. This is supported on POTS interfaces. However, VoIP-to-VoIP Hair-Pinning is not supported on Cisco IOS voice-enabled platforms except in CallManager Express with certain IOS releases.
I hope this help
John,
This depends whether or not you have the router configured as a MGCP gateway or H323. MGCP won't be possible to do this but if the GW is H323 then you can.
Using H323, the simplest way is to keep the traffic VoIP the whole time. Sure you wont use your PRI but you can still test that with a different unique pattern if you want. 1st you turn on the IP-to-IP GW feature.
voice services voip
allow connections h323 to h323
Setup your H323 gateway and then you create an inbound voip dial-peer and an outbound voip dial-peer. Note you can use the default inbound dial-peer if you like but remember this is a G729 dial-peer.
interface Loopback0
ip address 2.2.2.2 255.255.255.0
h323-gateway voip bind srcaddr 2.2.2.2
h323-gateway voip interface
gateway
dial-peer voice 1 voip
incoming called-number .
dial-peer voice 2 voip
description H323 dialpeer back to CCM
destination-pattern 3000
! example phone you are trying to call
session target ipv4:1.1.1.1
! 1.1.1.1 is ip of your CCM
Then on CCM setup the H323 gateway using the H323 source address you configured on the gateway. Setup any gateway specific settings and unique inbound CSS with a partition containing the pattern you would like to get to.
Additionally you could add a 2nd PRI/BRI port to the H323 gateway and configure it as a PRI switch on that port. Configure your dial-peers correctly and you can effectively loop your calls.
Please rate any helpful posts
Fred
Fred,
Thanks for your answer it was very helpful (I rated it up), unfotunately, my router is configured as MGCP and with me being more of a voice guy and not a router guy I don't know how to reconfigure it.
John,
If this isn't a production router and you would like assistance configuring H323, I'm sure we'll be happy to help you. Just post some dialplan info of the calling and called number.
Thinking about this, in theory it can be done with MGCP as well, though I've never tried it. This would require a 2nd PRI/BRI port. You would register this port just like the first. To achieve the call routing you need to craft your CSS and partitions correctly on your phones and the inbound gateway options.
Fred
Here is our external dial plan for 911, which is the number we want to test:
Results Summary
Calling Party Information
Calling Party = 1000
Partition =
Device CSS =
Line CSS =
AAR Group Name =
AARCSS =
Dialed Digits = 911
Match Result = RouteThisPattern
Matched Pattern Information
Pattern = 911
Partition =
Time Schedule =
Called Party Number = 911
Time Zone =
InterDigit Timeout = NO
Allow Device Override = Disabled
Outside Dial Tone = NO
Call Flow
Directory Number :DN= 911
Partition =
Call Classification = OnNet
Forwarding Information
ForwardAll : DN = VoiceMail = No CSS =
ForwardBusy
Internal : DN = 912 VoiceMail = No CSS =
External : DN = 912 VoiceMail = No CSS =
ForwardNoAnswer
ForwardNoCoverage
CFDF : DN = 912 VoiceMail = No CSS =
ForwardUnregistered
Pickup Group Number =
Device :Type= CTI Route Point
Device Status = UnKnown
Device Name = rp911
Ignore Presentation Indicators = Disabled
LoggedIntoHuntGroup = Yes
Alerting Name =
AAR Group Name =
AAR Calling Search Space =
AARVoiceMailEnabled = No
AARDestinationMask =
AAR Prefix Digits =
Alternate Matches
Note: Information Not Available
I don't really have a dial-plan for the incoming number, it would just be a phone on the Call Manager, let's say extension 1000.
Also, the router is a 2811 and the only options in Call Manager when adding a new gateway are MGCP and SCCP, I don't think I can configure it as H323.
Thanks for the help, this is a great forum.
John,
Looks like you don't have CSS or Partitions set. Thats fine we will just add some for inbound only. H323 gateways aren't added as a hardware type, they have an option just as H323 Gateway.
Here is the configuration
Router
enable
config t
voice services voip
!this is a mid 12.3T and later feature I believe
interface Loopback0
!example IP 2.2.2.2
gateway
codec g711ulaw
no vad
description H323 dialpeer back to CCMSUB
destination-pattern 911
codec g711ulaw
no vad
! 1.1.1.1 Sub IP
dial-peer voice 3 voip
description H323 dialpeer back to CCMPUB
codec g711ulaw
no vad
session target ipv4:1.1.1.2
preference 1
! 1.1.1.2 Pub IP, this is for redundancy
On CCM
Add a Partition, H323GW-IN
Add a CSS, H323GW-IN
Add Partition H323GW-IN to CSS H323GW-IN
Then we will add a translation pattern to convert 911 to an example extension 2000. This will allow you to terminate the call when it comes back in. You will need two phones to test this, Calling phone 1000 and destination phone 911/2000.
Add a Translation Pattern
Pattern 911
Partition H323GW-IN
CSS
!this is assuming you aren't using CSS.
!if you are set this to a CSS that can get to the example phone DN 2000
Called Party Transformation Mask set to 2000
Make sure you have an IP phone with the example DN or a DN of your choice.
Now add the gateway
Gateway Type, choose H323 Gateway
Gateway Protocol, choose H225
Device Name, 2.2.2.2
!that is my example IP, use what you assigned to your loopback0
Device Pool, choose a device pool using G711
Calling Search Space, use H323GW-IN
Then lastly add your gateway, 2.2.2.2, to a Route Group and Route List you are routing with(this is outbound from the phone). Make sure it's at the top of the list.
Now if you are really trying to test your MGCP, this won't effectively do this, since your route list is going to send out to the H323. It will test your CCM call routing up to the Route List selection. Also I'm posting this more for learning and lab purposes and wouldn't recommend creating configurations like this on a production network.
Let me know how this works for you.
Fred
Fred,
I am just now getting back to this project after being out of the office for a week.
I am getting hung up when I try to configure the loopback interface. I assume the loopback interface should be the address of the router itself but when I enter it i get an overlap error:
voicelabgw02(config)#interface loopback0
voicelabgw02(config-if)#ip address 172.20.20.2 255.255.255.0
% 172.20.20.0 overlaps with FastEthernet0/0
Should I be using a different address?
Thanks again for your help.
John,
Loopback addresses are usually used on the router to source applications to. They are their own IP address. Most admins use a /32 IP and populate that IP in the route table so it's accessible remotely. In my scenario you don't have to use a loopback, it's just best practice.
Fred
