10-21-2012 10:29 PM - edited 03-16-2019 01:48 PM
Hi all
I configured extension mobility on cisco call manager express but i dont know how to configure it so my user's can set their passwords individualy like it hapens in call manager environments where at the time of log out user have an option of " set pin " so the user can set the password privately, but i dont know how to enable this feature on call manager express ............... so please let me know how this feature could be used in call manager express.
Hope you guys will help and sooner to reply me.
Salman
Solved! Go to Solution.
10-25-2012 02:47 PM
Hello Salman,
The user will access just his profile.
If you have not installed/enabled the web GUI please check the following link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmegui.html
HTH,
Alex
*Please rate helpful posts
10-22-2012 12:28 AM
Hello Salman,
The users may change their settings under the Web GUI (with browser from their PC) of the CME
HTH,
Alex
10-23-2012 12:30 AM
Dear Alexander
thanks for reply but i cant access the call manager express the way you told me also i need to ask you one question is that by doing the above process will the end user get the GUI interface of whole call manager express or just his profile ? like its hapens in Call manager when user access url like https:// ip address of call manager/enduser.html so its got only the access to his profile and then the user can make changes ....... so will your mentioned process work like the same way as this url
https:// ip address of call manager/enduser.html work in call manager ?
please elaborate.
Thanks again.
Salman Jamshed
10-25-2012 02:47 PM
Hello Salman,
HTH,
Alex
