Reset password of PLM running on CUCM
Hello everyone!
I am running CUCM 10.5 and it has the coresident PLM server.
I took this over for someone else who is no longer here. I changed the CUCM admin and OS password but PLM is still not letting me log in. Any idea how to reset that?
Thanks.
Login on cucm cli
license management reset user password
Carlo
Please rate all helpful posts "The more you help the more you learn"
5 Replies 5
Login on cucm cli
Carlo
I suppose u have changed the Application Password and not the OS password since u are not able to login into PLM through GUI.
OS credentials are used when u create a product instance and then, u can synchronise.
you can also refer the discussion
https://supportforums.cisco.com/discussion/12551331/plm-not-answering-web-login
regds,
aman
That was it! Thanks Carlo!
+5 for Carlo
Thank you!
Co-Resident PLM with 10.5.2.
1) The command mentioned : license management reset user password
does this reset the Master Account created during PLM installation ?
(For us this Master Account user name is not the same as the CUCM OS Administrator user name created at installation (level 4 privileges))
2) In CUCM is the Master Account user name created at install listed in CUCM as an Application user?  or listed anywhere in CUCM as a user for PLM ?
installation was performed by a 3rd party vendor a long time ago, and I need to reset that Master Account user's password.
