03-21-2014 06:55 AM - edited 03-16-2019 10:13 PM
Hi Everyone,
We are trying to reset the OS admin/Platform password for UCCX Version: 9.0.2.10000-71 on a Sub.
Will appreciate any suggestions/methods which can be used - without having to reboot the cluster or the pub.
03-21-2014 07:34 AM
Have you seen this? No reboot required.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/cli_ref/9_1_1/CUCM_BK_C6AE17AA_00_cucm-cli-reference-guide-91/CUCM_BK_C6AE17AA_00_cucm-cli-reference-guide-91_chapter_0110.html#CUCM_CL_SB2BA64F_00
03-21-2014 07:35 AM
Hi Mavinktul,
This process should be the same as resetting the administrator password on the CUCM.
username: pwrecovery
password: pwreset
It will then check if you have physical access to the server/VM by asking you to load and remove a disc. Any disc/iso image can be used for this.
06-19-2014 04:18 AM
I am following the same procedure and at the end got message "the password has been reset" but when i am going to login it still give same incorrect login error.Please help.
