Hi, this is my issue, we have remote sites which use a central internal server to run 'Windows Updates', everytime a PC starts to run 'Windows Updates' the network on that remote site gets congested then the phones stop working. Is there any way to prevent 'Windows Updates' to utilize 100% of the available bandwidth?
I have a policy map configured and www(http) is set on the low priority, but it seems that is not enough... here is what I got.:
class-map match-all HI
match access-group name hiclassacl
class-map match-all LO
match access-group name loclassacl
class-map match-all RT
match access-group name rtclassacl
policy-map AVPNCOS
class RT
set ip dscp ef
priority 600
class HI
set ip dscp af31
bandwidth remaining percent 60
class LO
set ip dscp af21
bandwidth remaining percent 30
class class-default
set ip dscp default
bandwidth remaining percent 10
ip access-list extended hiclassacl
permit tcp any eq telnet any
permit icmp any any
permit tcp any eq lpd any
permit tcp any eq 5020 any
permit ip any 0.0.245.0 255.255.0.255
permit tcp any 10.20.238.0 0.0.0.255
permit tcp any eq 1100 any
permit tcp any eq 1105 any
permit tcp any eq 1106 any
permit tcp any any eq 2000
permit tcp any any range 11000 11999
permit tcp any any eq 2428
permit tcp any any eq 2427
permit udp any eq tftp any
permit tcp any eq ftp any
permit tcp any 10.20.244.0 0.0.0.255
ip access-list extended loclassacl
permit tcp any eq www any
permit tcp any eq 1137 any
permit tcp any eq 8080 any
permit tcp any eq 1131 any
permit tcp any eq 3389 any
permit tcp any eq smtp any
permit tcp any eq 143 any
ip access-list extended rtclassacl
permit udp any any range 16384 32767
