Restricted Pots Dial for a specific calling number
azher.amin
Hi All,
I have calls coming via SIP trunk in a 2611xm router that has 4 FXO lines for dialing out to campus exchange. The setup is working for both inbound and outbound calls. Users are dialing a standard pattern e.g. XXXX , 9XXX XXXX etc.
Now is there a way to restrict incoming SIP call i.e. from the calling number e.g. 1000 to go out via a specific FXO port, while rest of the the calls should go out via remaining 3 FXO ports.
-Azher
Current Config:
>>>> Four Analog FXO
voice-port 1/0/0
input gain 10
no comfort-noise
connection plar 8000
caller-id enable
voice-port 1/0/1
input gain 10
no comfort-noise
caller-id enable
voice-port 1/1/0
input gain 10
no comfort-noise
connection plar opx 8898
voice-port 1/1/1
input gain 10
no comfort-noise
connection plar opx 8000
>>>> Dial-Out
dial-peer voice 3 pots
description Dialout via 3862
destination-pattern .
incoming called-number .
port 1/0/0
dial-peer voice 4 pots
description Dialout via 3015
preference 1
port 1/0/1
dial-peer voice 5 pots
description Dialout via 8797
preference 2
port 1/0/1
dial-peer voice 10 pots
description Dialout via 8898 for User-X <<<< Restriction Required
preference 3
port 1/1/0
sip-ua
retry invite 3
retry response 3
retry bye 3
retry cancel 3
timers trying 1000
sip-server ipv4:10.10.10.1
>>> Incoming calls via POTS to SIP Server
dial-peer voice 2 voip
preference 1
destination-pattern 8...
progress_ind setup enable 3
session protocol sipv2
session target ipv4:10.10.10.1:5060
session transport udp
dtmf-relay rtp-nte
codec g711ulaw
no vad
odaijeriss
yes you can do that by configuring corelist, so that calls comming from 1000 will be assinged incoming corelist that has a memeber, and at the same time an outgoing corelist should be configured (which has that member) and should be assigned to the dial peer pointing to FXO port 0/0/0. so this will force extensiont 1000 to go through FXO port 0/0/0
you can do the same things to force the other extensions to go throught the other ports.
Best Regards,
Odai Jeriss
But the extensions are not local, this router is acting as SIP to PSTN and vice versa. Calls are landing in via a SIP trunk.
-Azher
thats should not affect as you can configure an incomming dial peer which use  "answer-address ANI_String" to catch the calling number in incomming calls and  this dial peer will assign incomming corelist which will be used to direct the  call to the specific FXO port.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
or you can use "incoming uri {called|calling} tag" see the following link for details
http://www.cisco.com/en/US/docs/ios/voice/ivr/configuration/guide/gt_url.html#wp1055648
Best Regards,
Odai Jeriss
