Restricted vs unrestricted
balukr
Level 2
Level 2
How to find out migrated/upgrade CUCM 8.6 version is restricted or unrestricted? Is there any command on OS admin I can verify this ?
Jaime Valencia
Just log into CCMAdmin and if it shows unrestricted in the version you're running that flavor, if it doesn't show anything else, it's restricted
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Java, Thank you so much for your quick response.
