02-12-2015 09:10 PM - edited 03-17-2019 01:57 AM
Friends,
To restrict sending calling name on SIP trunk, "Calling Name Presentation" on SIP trunk should be set to Restricted. Seems if I set this parameter to Restricted, CUCM is sending From field as <anonymous@anonymous.invalid> and in result, called party can't see even the calling number. How to correct it while CUCM should send calling number in From field and restrict only calling name?
Precisely, if either of the parameter "Calling Name Presentation" or "Calling Line ID Presentation" is set to Restricted, From field is sent as anonymous.
Same is working as expected on H.323 by disabling only "Display IE Dilevery" parameter in H.323 configuration.
Vivek
Solved! Go to Solution.
02-14-2015 12:16 AM
Hi Suresh,
Thank you very much for the hint.... then I realized the interactions between RPID, Asserted, Privacy, Calling Line ID and Calling Name Presentation parameter and tried to cover all combinations. Seems all combinations are possible and it's now depends on remote end configuration how to fetch the ANI to display on phone. Results are mentioned below.
Case1 | Asserted - Off | ||||
RPID - Off | |||||
Calling Line-ID Presentation | Calling Name Presentation | Result1 (SIP From) | Conclusion | ||
Allow | Allow | name <number@localhost> | "CLI" and "Name" presentation parameter can be used to control sending name and number in From field of INVITE message. | ||
Allow | Restrict | anonymous <number@localhost> | |||
Restrict | Allow | name <anonymous@localhost> | |||
Restrict | Restrict | anonymous <anonymous@localhost> | |||
Case2 | Asserted - Off | ||||
RPID - On | |||||
Calling Line-ID Presentation | Calling Name Presentation | Result1 (From field in INVITE) | Result2 (RPID privacy header) | Conclusion | |
Allow | Allow | name <number@localhost> | off | When RPID is being used, "CLI" and "Name" presentation parameter can be used to control sending name and number in From field along with marking required privacy in RPID header. | |
Allow | Restrict | anonymous <number@localhost> | uri | ||
Restrict | Allow | name <anonymous@localhost> | name | ||
Restrict | Restrict | anonymous <anonymous@localhost> | full | ||
Case3 | Asserted - On & Privacy - None | ||||
RPID - Off | |||||
Calling Line-ID Presentation | Calling Name Presentation | Result1 (From field in INVITE) | Conclusion | ||
Allow | Allow | name <number@localhost> | When RPID is off and Asserted Privacy is None, From field is always populated with name and number. "CLI" and "Name" presentation parameter can not be used to control sending name and number in FROM field of INVITE message. | ||
Allow | Restrict | name <number@localhost> | |||
Restrict | Allow | name <number@localhost> | |||
Restrict | Restrict | name <number@localhost> | |||
Case4 | Asserted - On & Privacy - Id | ||||
RPID - Off | |||||
Allow | Allow | anonymous <anonymous@localhost> | When Asserted Privacy is Id, From field is always populated as Anonymous. "CLI" and "Name" presentation parameter can not be used to control sending name and number in FROM field of INVITE message. | ||
Allow | Restrict | anonymous <anonymous@localhost> | |||
Restrict | Allow | anonymous <anonymous@localhost> | |||
Case5 | Asserted - On & Privacy - None | ||||
RPID - On | |||||
Allow | Allow | name <number@localhost> | off | When asserted is on with privacy none and RPID is also on, From field is always populated with name/number. "CLI" and "Name" presentation parameter can not be used to control sending name and number in FROM field of INVITE message. | |
Allow | Restrict | name <number@localhost> | name | ||
Restrict | Allow | name <number@localhost> | uri | ||
Restrict | Restrict | name <number@localhost> | full | ||
Case6 | Asserted - On & Privacy - Id | ||||
RPID - On | |||||
Allow | Allow | anonymous <anonymous@localhost> | off | When Asserted Privacy is Id, From field is always populated as Anonymous. Since RPID is on, "CLI" and "Name" presentation parameter can be used for marking required privacy in RPID header. | |
Allow | Restrict | anonymous <anonymous@localhost> | name | ||
Restrict | Allow | anonymous <anonymous@localhost> | uri | ||
Abstract:
1. When asserted and rpid is not used, "Calling Line ID" and "Calling Name" presentation parameter can be used to control sending name and number in From field of INVITE message.
2. When only rpid is on (and asserted is off), "Calling Line ID" and "Calling Name" presentation parameter can be used to control sending name and number in From field of INVITE message. In addition, privacy header shall be added to RPID as per "Calling Line ID" and "Calling Name" presentation parameter values configured.
3. When only asserted is on and privacy is none (and rpid is off), From field is always populated with desired name and number in From field of INVITE message. "Calling Line ID" and "Calling Name" parameter has no role in controlling name and number in From field of INVITE message.
4. When only asserted is on and privacy is id (and rpid is off), From field is always populated as Anonymous. "Calling Lline ID" and "Calling Name" parameter has no role in controlling name and number in From field of INVITE message.
5. When both asserted and rpid is on (and privacy is none), From field is always populated with desired name and number in From field of INVITE message. "Calling Line ID" and "Calling Name" parameter will mark the required privacy marking in rpid header in INVITE message depends on "Calling Line ID" and "Calling Name" values.
6. When both asserted and rpid is on (and privacy is id), From field is always populated as Anonymous. "Calling Line ID" and "Calling Name" parameter will mark the required privacy marking in ripid header in INVITE message depends on "Calling Line ID" and "Calling Name" values.
Vivek
02-13-2015 02:20 AM
If you are using CUBE you may be able to use SIP Profiles to strip out the info.
With CUCM you may be best to write a lua script.
Aaron
02-13-2015 02:34 AM
Hi Aaron,
Thanks...
Just to get your point, what is the purpose of then "Calling Name Presentation" and "Calling Line ID Presentation" parameters on SIP trunk?
Are both parameters doing the same job of replacing From field with anonymous (when either one is set to on)?
Vivek
02-13-2015 04:46 AM
if Privacy is set to Default, then no name & no number displayed.
You can keep both the asserted id & remote party id Checked & asserted type be Default. just change the privacy to None.
Pls try that and let us know how it works
02-14-2015 12:16 AM
Hi Suresh,
RPID - Off | |||||
RPID - On | |||||
RPID - Off | |||||
RPID - Off | |||||
RPID - On | |||||
RPID - On | |||||
Abstract:
Vivek
02-14-2015 12:21 AM
02-19-2015 06:53 AM
If I could rate you 10 for thoroughness, I would :-)
02-19-2015 08:53 AM
Thanks Aaron for the feedback :)
02-13-2015 04:34 AM
Vivek,
Try the following steps:
1) Under SIP Trunk Configuration, Uncheck "Asserted-Identity"
2) Set Calling Name to restricted
3) Leave Calling Number as default
4) Save, Apply Config, Reset Trunk
Let me know if this helps. -Dennis
02-14-2015 12:24 AM
Hi Dennis,
True. I have observed other cases as well and attached the same.
Thank you...
Vivek
02-19-2015 08:55 AM
Thanks Jaime for the feedback :)
