Cisco Community Designated VIP Class of 2020
189
Highlighted
Beginner
Restricting PSTN Calls to one or two numbers
I would like to assign two PSTN numbers to be called from a specific DN.
For Example,
DN = 112 should only make calls to following numbers only.
+256700400100
+256700400101
Thanks in Advance,
Nooruddin
Everyone's tags (1)
3 REPLIES 3
Hall of Fame Cisco Employee
Re: Restricting PSTN Calls to one or two numbers
You don't mention what you use (always mention products you're working with and versions, not just what you want or your problem), so I'll assume this is with CUCM.
Configure those two numbers as exact route patterns in a special partition only that device will have in his CSS.
java
if this helps, please rate
Beginner
Hi Jamie,
Sorry for not mentioning,
I am using Cisco router 2821 with CME.
Can you please provide more details? Like command and procedure.
Thanks alot
Beginner
First of all 28xx routers are eol products
A COR list can restrict the access
Create a dial-peer with patters +25670040010[1,2]  assign it as per the documentation
https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/42720-configuring-cor.html
Content for Community-Ad
FusionCharts will render here
