Highlighted
Beginner
retrieve calls from past days
Hi all;
       I have a cisco ISR4331/K9 with E1, I need to get calls history from a week ago, using this file: https://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_s04_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1249092
I couldn't find calls in history.
Is there a way to retrieve or get calls from 8 days ago? how can I do that? is possible that someone connect directly to the router and make a call?  how can I get the DID for this Cisco device
1 REPLY 1
Highlighted
You can set a max of 500 calls to be contained in that table. If you need to retrieve call history you would want to setup CDR or gw-accouting -
https://www.cisco.com/c/en/us/support/docs/voice/h323/14068-cdr-logging.html
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
Content for Community-Ad
