Review installed licenses cisco call manager V4.3
alfonso.cornejo
Level 3
Level 3
Hi!
I have and old cisco call manager V4.3 and i need to review with licenses it has installed, does anyone know how can i get that information from that version??? i checked in the licenses part of the system but nothing is there.
Thanks in advance!
Jaime Valencia
There were no licenses installed on windows versions, you cannot get any info from the server. You need to review the actual paper licenses.
java
if this helps, please rate
Jaime Valencia
java
