07-07-2011 08:44 PM - edited 03-16-2019 05:50 AM
We have just upgraded CUCM from 6.1.3 to 7.1.5. and our 2821 gateway from 12.4.21 to 12.4.25e
Rightfax 9.4 FP1 SR4 was working fine before the upgrade.
Now we can't hear the fax tone when calling the server.
We see the call being picked up and rightfax show the extension and says brooktrout: receiving c:\program~1\RightFax\Doctra~1\................... but nothing happens.
Same problem occurs with H323 or SIP trunk and whether the call is internal or external so it seems that the issue is with CUCM and not the trunk or 2821 configuration
The call path is 2821MGCP -> CUCM 7.1.5 -> Rightfax SR140 (SIP or H323).
Any idea or pointer to what could be causing this would be greatly appreciated
Solved! Go to Solution.
07-08-2011 06:29 AM
having been through severe pain with rightfax 9.4 in the past I would recommend that you downgrade your gateways back to the IOS you were running previously.
12.4 IOS has LOTS of bugs relating to T.38 fax traffic. on the 3 installs of rightfax I have completed, most of the problems experienced were with the IOS on the gateways.
07-08-2011 06:29 AM
07-08-2011 09:41 AM
That was it.
Went back to 12.4.21a and it works fine with both SIP and H323 trunks.
Grrrrrrrrrrrrrrrrrrrrrrrr
