10-18-2012 09:07 AM - edited 03-16-2019 01:45 PM
I have an SRST router in an off site location running voice through the CUCM in our main office. I have added two PRIs for a rightfax service that does not connect to the CUCM but goes right through the router acting as a gateway.
I can dial into the rightfax server but I am having difficulty dialing out. Says poor line condition. I did a search on the q931 debug (below) and it seems to be a translation rule issue but I cannot see where. The telco pushes 4. The 8... is the voice where 0... is the fax line
Any help?
David
Dial-peer and Trans
voice translation-rule 1
rule 1 /8120/ /8110/
voice translation-rule 2
rule 1 /^651361..../ /9\0/
rule 2 /\(^[2-9].........\)/ /9\1/
voice translation-rule 50
rule 1 /^81\(..\)/ /65136181\1/
voice translation-profile Inbound
translate calling 2
translate called 1
voice translation-profile SRST
translate calling 50
VSMNSRST01#sh run | b dial-p
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
port 0/0/0:23
dial-peer voice 2 voip
preference 2
destination-pattern 81..
session target ipv4:172.31.0.11
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
ip qos dscp ef signaling
no vad
dial-peer voice 3 voip
preference 1
session target ipv4:172.31.0.10
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 9110 pots
destination-pattern 911
port 0/0/0:23
forward-digits all
dial-peer voice 90000 pots
destination-pattern 9[2-9].........
port 0/0/0:23
forward-digits 10
dial-peer voice 910000 pots
destination-pattern 91[2-9]..[2-9]......
port 0/0/0:23
forward-digits 11
dial-peer voice 90110001 pots
destination-pattern 9011T
port 0/0/0:23
prefix 011
dial-peer voice 9111 pots
port 0/0/0:23
forward-digits all
dial-peer voice 99110 pots
destination-pattern 9911
port 0/0/0:23
forward-digits 3
dial-peer voice 94110 pots
destination-pattern 9[4-8]11
port 0/0/0:23
forward-digits 3
dial-peer voice 71 pots
preference 2
destination-pattern 7[2-9].........
port 0/3/0:23
forward-digits 10
dial-peer voice 72 pots
preference 1
forward-digits 10
dial-peer voice 73 pots
preference 2
destination-pattern 71[2-9]..[2-9]......
port 0/3/0:23
forward-digits 11
dial-peer voice 74 pots
preference 1
forward-digits 11
dial-peer voice 61 voip
destination-pattern 0202
session target ipv4:10.9.81.22
voice-class codec 1
voice-class h323 1
fax-relay ecm disable
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
ip qos dscp cs3 signaling
no vad
dial-peer voice 62 voip
destination-pattern 0210
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 63 voip
destination-pattern 024[48]
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 64 voip
destination-pattern 0269
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 65 voip
destination-pattern 040[78]
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 66 voip
destination-pattern 0293
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 67 voip
destination-pattern 0396
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 68 voip
destination-pattern 0418
voice-class codec 1
voice-class h323 1
no vad
Q931
Oct 18 15:53:24.314: ISDN Se0/3/0:23 Q931: Sending SETUP callref = 0x00A9 callID = 0x802A switch = primary-ni interface = User
Oct 18 15:53:24.314: ISDN Se0/3/0:23 Q931: TX -> SETUP pd = 8 callref = 0x00A9
Bearer Capability i = 0x9090A2
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Called Party Number i = 0xA1, '13012872637'
Plan:ISDN, Type:National
Oct 18 15:53:24.454: ISDN Se0/3/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80A9
Cause i = 0x8081 - Unallocated/unassigned number
VSMNSRST01#
VSMNSRST01#
Oct 18 15:53:24.482: ISDN Se0/3/0:23 Q931: Sending SETUP callref = 0x00AA callID = 0x802B switch = primary-ni interface = User
Oct 18 15:53:24.486: ISDN Se0/3/0:23 Q931: TX -> SETUP pd = 8 callref = 0x00AA
Standard = CCITT
Called Party Number i = 0xA1, '13012872392'
Oct 18 15:53:24.654: ISDN Se0/3/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80AA
