Ring Duration Before Auto Attendant
mohammed-amjad
Beginner
Beginner
I have Call Manager Express with Integrated Unity 8.0 and i wants to configure ring duration before auto answer the call.  How to configure this please?
6 Replies 6
mohammed-amjad
Beginner
Beginner
When anyone calls from outside its rigining 2 rings then its forwarding auto attendant i need 0 ringings how to configure this?
What do you mean by 0 ringing? If you want the call to go straight to the AA just make it ring the AA directly or do a Call Forward All on the phone to the AA.
Please rate helpful answers!
I mean if someone calling outside to the company they are getting 2 rings after 2 rings they are getting auto answer to dial the required extension.  I dont need like this instead this 2 rings i need 1 ring and or direct to auto answer. I am getting about this command because i have CME and integrated CUE and auto attendant is configured in the CUE.
To set this for a specific phone, change the call-forward noan command on the line. It should be Something like:
ephone-dn  1
number 1000
call-forward busy 1001
call-forward noan 1001 timeout 20 <<< change the timer to 5 seconds for example
There is also a global setting for all phones if Call Forward no answer is not set at the line level:
telephony-service
timeouts ringing 15 <<<
I dont need any ringing i need direct to auto answer whenever calling from outside from auto answer i will select the extension like below message.  I need the command to configure in cme or integrated cue.
http://docs.fortinet.com/fvox/cli-html/2-2-0/index.html#page/FortiVoice%20Online%20CLI%20Reference/config.3.39.html
ring-duration
Enter the number of seconds for the phone to ring before the auto attendant answers with the greeting message.
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Configure CFA if you're reaching a phone, or a translation rule to send the calls directly to the AA.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Recognize Your Peers
