11-23-2006 06:34 AM - edited 03-14-2019 06:57 PM
I have upgrade an CME 3.3 to 4.03. All the ring tones are stored under a subdirectory (rings) in the flash. All the old phones eg 7940 work fine. If I add a new phone e.g. 7941 i get the message ringlist has error. If I copy all the rings to the root directory and change the ringlist.xml then everything is working fine. Is it not possible to have the rings in a subdirectory with the new phone generation? I already tried to copy the ringlist.xml to the root and also to the subdirectory. Each time same message. Did also try with the alias command
Solved! Go to Solution.
11-23-2006 06:58 PM
Yes it is possible to place the ring tones under a directory using the new phones but you must use the alias command in your tftp server statments as shown below.
tftp-server flash:/Rings/RingList.xml alias RingList.xml
tftp-server flash:/Rings/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/Rings/Ring1.raw alias Ring1.raw
tftp-server flash:/Rings/Ring2.raw alias Ring2.raw
tftp-server flash:/Rings/Ring3.raw alias Ring3.raw
tftp-server flash:/Rings/Vibe.raw alias Vibe.raw
Note: Directory names are case sensitive.
Regards.
11-23-2006 06:58 PM
Regards.
12-28-2006 08:45 AM
Yes it works like that. Don't forget to change the RingList.xml. There should be no subdirectory (rings/). See below
tftp-server flash:rings/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:rings/RingList.xml alias RingList.xml
tftp-server flash:rings/3s-hello.raw alias 3s-hello.raw
tftp-server flash:rings/24ctu.raw alias 24ctu.raw
RingList.xml
Like that it works with the old phones e.g. 7940 and also with the new ones 8e.g. 7941)
