1042
Highlighted
Beginner
Beginner
Ringback tone issue with call transferred through Unity Connection.
we have ring back tone issue with below scenario
PSTN -----PRI (E1)----SIP VGW--- SIP trunk-----CUCM----SIP TRUNK-----CUC(AA)---Transferred Calls to Internal IP Phone.
When incoming call trough above scenario and Transferred by Unity AA to internal extension , Caller not get ring back tone .
Our action
1-Enable PRACK on SIP trunk between GW and CUCM also on SIP TRUNK between CUCM and CUC
2-Enable PRACK on Voice Gateway which enabled by default
Result :
Same issue
Kindly check SIP VGW logs below  debugs
debug voip ccapi inout
debug ccsip message
3 REPLIES 3
Highlighted
Working asa designed. Once the call has been answered by the CUC call handler, a "200 OK" marks the dialog establishment. With SIP, none of the devices will send a '"180" or "183" in-dialog.
A couple of workarounds -
1. Invoke Annunciator on CUCM for proxy ring back.
2. Use H.323.
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
Highlighted
Hello Nipun
Thanks for your support.
I already configured Sip trunk with media resources contain Annunciator .
Highlighted
Nipun,
I dont think this ia working as designed. Normally the first leg of the call ie call to AA will not get a ring back but the transfer to the phone should generate ring back to the caller.
My first question is does ring back work on normal calls from the PSTN?
Please rate all useful posts
Content for Community-Ad
