Ringtones preference and EM
RedingtonGomes
Hello everyone,,
is it possible to keep the ringtones preferences for one or many lines with the extension mobility.
When i set the preference for my lines, and then i logout and re-login the preferences will not be saved.
Thanks for your help,
Redington.
Jaime Valencia
No, that's not possible,
java
if this helps, please rate
