Route calls betwen clusters
Rod.Blackie
I have a UCM cluster in the UK and One in France. Both systems are unique to each country.
I have a VPN that connects the UK and France.
What is the best way to route (on-net type calls) between each cluster over the VPN.
Rod
Hi Rod.
H323 ICT is an option but you can also use a SIP trunk between cluster but I usually prefer H323.
Have a look to SRND
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/trunks.html
Carlo
Please rate all helpful posts "The more you help the more you learn"
Assuming both clusters are 8.6 or higher, we recommend a SIP trunk.
If there's anything below 8.6 in the mix, an ICT.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
