05-12-2017 11:42 AM - edited 03-17-2019 10:19 AM
Hello All,
Let me start by saying I am not a VoIP technician, merely attempting to help a client solve an issue. The client is requesting that all incoming calls bypass the auto attendant and route directly to extension 103. I have not been able to achieve this goal... I have attempted to read through several posts and documentation, but I've not been able to find anything that achieves the goal. I apologize in advance for my limited knowledge. Please find attached to this post the current configuration.
05-12-2017 12:04 PM
Is that a DID?
What are they dialing?
05-12-2017 12:20 PM
hi ,
you can translate the incoming numbers to the Ext you like
voice translation-rule 7
rule 1 /^775-532-8524/ /xxx/ ! note that xxx is the ext number you want the calls to go to
rule 1 /^775-532-8522/ /xxx/
rule 1 /^775-532-8300/ /xxx/
rule 1 /^775-532-8527/ /xxx/
voice translation-profile trans_Inbound
translate called 7
dial-peer voice 10 pots
translation-profile incoming trans_Inbound
incoming called-number .
direct-inward-dial
let me know if it works :)
Fares
05-15-2017 11:02 PM
Could you please upload the running-config of the device here. Do " sh run ". copy and paste the result.
05-18-2017 02:07 AM
Since you are using FXO lines, you may just change the command "connection plar opx" under FXO ports to be 103 instead of 701.
For example for line
775-532-8524 located at port 0/1/0
Change the plar destination to 103 instead of 701 which is the extension of your AA as I see in your config.
voice-port 0/1/0
connection plar opx 701 103
