10-04-2022 07:39 AM
I have a need to create a new Route Pattern for 1 phone. I can do that but how do I get that 1 phone to use the new Route Pattern?
Thanks in advance!
Solved! Go to Solution.
10-04-2022 07:45 AM - edited 10-04-2022 07:45 AM
Create a new partition let’s assume p_new Put that RP in a P_new. Create a new css css_new and add the partition p_new
assign this css_new on the line. Now your phone can reach the new route pattern
10-04-2022 08:06 AM
What route patterns a phone can use is defined by what calling search space that the device and/or directory number has been assigned with. In the CSS you have a list of partitions and anything in any of these PT's , including RP's is what the device has access to use.
10-04-2022 08:10 AM
As Nithin pointed out, you can achieve this by creating a new partition, and placing it in a new Calling Search Space. Then, assign your newly created partition to the route pattern in question. After that, assign your newly created Calling Search Space to the phone that you want to reach the route pattern.
Also, to give the phone the ability to access other patterns, you can simply add the existing partitions of those other patterns to the new Calling Search Space.
