Walkthrough Wednesdays
165
s-bruening
Beginner
Route Pattern for third-party SIP Devices
we have connected our Nokia E-Series Phones to our CUCM 6.1 via Sip. Everything
is fine so far. The issue is that the phonenumers in the mobilephone
addressbooks are in an international form e.g. +4901709197... or
+440207..., and I don't know how a route pattern needs to be look like to
match such numbers. In the moment I got the error message "address is
not in use" on the nokia phone, when I try to dial such a number and couldn't see anything in the isdn debug.
We have added one E61 via SCCP to the CUCM 6.1. The problem is nearly the same, but with this phone I got an ISDN debug output, which looks like as the callmanager or gateway just ignores the "+" and dropps it.
The only existing outgoing route pattern we have in the moment is 0.X with activated
overlap sending.
Any ideas to make it possible to dial these "+ numbers"??
2 REPLIES 2
gogasca
Advocate
the problem with Intl numbers is the lenght
try Application Dial Rules to see if can help you for some countries...we raised a defect against that and we are working in this
+ since plenty of customers are requesting this feature.
pasimahone
Beginner
Is there any specific reason why you want to use SIP?
You could also try Nokia Intellisync Call Connect for Cisco client which enables SCCP to Nokia E-series phones.
Nokia SCCP client converts + sign to 00 by default. So when you make a call e.g. to +49017091197.. the client actually calls to 0049017091197
You can find latest client and documentation from here: http://www.businesssoftware.nokia.com/nokia_intellisync_call_connect_for_cisco_downloads.php
Pasi
Content for Community-Ad
Spotlight Awards 2021
