Route Pattern Question. Can a Route Pattern contain an astrick (*) in the middle of the dial string?
jamize
We are trying to connect a Call Manager 8.6.2SU3 with Vocera and Nurse Call systems via SIP Trunks.  The vendor has requested the following Route Pattern: 2051169760.!*!#
When we try to dial a number such as: 2051169760338*6678770# we hear "Your call can't be completed as dialed".
Can the Route Pattern contain a (*) in the middle of the dial string?
Jeff
You are welcome Jeff, Glad issue found and isolated.
Br,
Nadeem
P.S Please rate for all useful Post.
Br, Nadeem Please rate all useful post.
Nadeem Ahmed
Hi Jeff,
I just tested in my lab with an environment CCM----SIPTRUNK----VGW and configured the same RP as mentioned call is being sent from CUCM to my VGW however it works as i was expecting to be. but crux was CUCM didn't override (*) and sent the call to next hop over a SIP trunk.
Here is trace collected on VGW
og Buffer (500000 bytes):
*Oct 21 22:31:59.438: %ENVMON-4-FAN_LOW_RPM: Fan 1 service recommended
*Oct 21 22:32:12.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Here INVITE Received from CUCM.
Received:
INVITE sip:2051169760388*6678770@XX.XX.XX.XX:5060 SIP/2.0
Via: SIP/2.0/UDP XX.XX.XX.XX:5060;branch=z9hG4bKa8aeeae7d
From: "Nadeem'Phone" <sip:5000@XX.XX.XX.XX>;tag=13126~eada4422-7620-4109-867b-63b7c5eb269c-39467100
To: <sip:2051169760388*6678770@XX.XX.XX.XX>
Date: Wed, 21 Oct 2015 15:45:31 GMT
Call-ID: c11ca500-6271b31b-45-cb64d0a@XX.XX.XX.XX
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:XX.XX.XX.XX:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 3239879936-0000065536-0000000003-0213273866
Session-Expires:  1800
P-Asserted-Identity: "Nadeem'Phone" <sip:5000@XX.XX.XX.XX>
Remote-Party-ID: "Nadeem'Phone" <sip:5000@XX.XX.XX.XX>;party=calling;screen=yes;privacy=off
Contact: <sip:5000@XX.XX.XX.XX:5060>;video;audio;+u.sip!devicename.ccm.cisco.com="SEPD0C7891413E1";bfcp
Max-Forwards: 69
Content-Length: 0
*Oct 21 22:32:12.250: //72979/C11CA5000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 21 Oct 2015 22:32:12 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
SIP/2.0 404 Not Found
To: <sip:2051169760388*6678770@XX.XX.XX.XX>;tag=1658B18-D2A
CSeq: 101 INVITE
Reason: Q.850;cause=1
Content-Length: 0
*Oct 21 22:32:12.250: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:2051169760388*6678770@XX.XX.XX.XX:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Br,
nadeem
Thanks for testing Nadeem Ahmed. We were able to get it working.  It ended up being on the vendor side.  They weren't accepting the string.  Thank you for testing.
Br,
Nadeem
