04-11-2013 07:44 AM - edited 03-16-2019 04:45 PM
I have 2 sites, each site has one CUCM, CUCM has inter cluster trunk, the number section of the site1 is the 11XX ,site 2 number section is 22xx, configured with the correct route pattern, the communication is well.
If this site1 CUCM add number segment 10XX, if the site 2 is not configured route Pattern to 10xx,
Is 10xx can dial 22xx? 22xx can not dial 10xx? Or 10xx and 22xx can not dial?
Bet Regards!
Solved! Go to Solution.
04-11-2013 08:01 AM
Hi Nian,
Phone 10XX will be able to dial 22XX.
Phone 22XX will not able to dial to 10XX because as you said there's not a route pattern (22XX) point to this site.
I recommend you two create these two pattern:
Site 1: 22XX--> Pointing to to Site 2
Site 2: 1[10]XX --> Pointing to to Site 1
Please rate all useful posts
Favor calificar todos las respuestas útiles.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice, CCNP Voice Certified
04-11-2013 08:01 AM
Hi Nian,
