05-04-2019 01:04 AM
can we create multiple route pattern for the same function?
Scenario,
and route pattern which has a transformation mask (the purpose is to mask caller id , for example if the DN 6700 dial 9.00! the called party should see 00+countrycode+ 23456700number, so the mask is 00+countrycode+2345XXXX)
Two phones 6701 and 6702 has external phone number mask 23456788.
Now the problem is if I assign the css which has the route pattern 9.00! to these phones
if 6701 dials the pattern 9.00! 00+countrycode +23456701
if 6702 dials the pattern 9.00! 00+countrycode +23456702
But what actually I need if both phone dial 9.00! i need to show 00+countrycode+ 23456788.
and rest of the phone should show as 00+countrycode+ 2345XXXX.
What is the solution ?
05-04-2019 03:45 AM
as stated in my previous post, set the external phone number mask to be full e164
05-04-2019 03:50 AM
05-04-2019 05:53 AM
In that case you need to put the granularity on the 9. Route patternby addi g the calling partu transformation only to that route pattern and leave all other rp s untouched.
