Route Pattern
Ali Bahnam
I used this pattern 9.XXXX and it is work fine. But when I trying to 91.XXXX it is not worked.
Anyone can advise how I can use two digits before the dot? I need to press 91 then I will get tone after that I need to enter my DN and the 91 will be canceled (predot)
5 Replies 5
Jaime Valencia
You'll have to explain exactly what's wrong here, you can use either, and it will discard predot, if configured to.
If your problem is the secondary dial tone, that's because you have DNs/Patterns overlapping, which do not have the secondary dial tone checkbox checked.
http://docwiki.cisco.com/wiki/CUCM_Dial_Plan_and_Call_Routing_FAQ#When_should_I_get_the_secondary_dial_tone.3F.3F
java
if this helps, please rate
Thank Jaime,
My point that I need to use the 91 as an outside dial tone instead of 9, is this possible?
Yes, assuming you configure this properly.
java
ok, Is there any specific configuration, because when I configured it I got the outside dial tone once click on 9 as the cucm doesn't wait for the next digit (1).
Please advise,
That completely depends on your dial plan, no one can tell you what to configure/change, you have access to the whole dial plan, and you should be able to tell what needs to be adjusted, read the link I posted to understand the theory of when you should get it.
java
