Router 2901 as VoIP gateway
espinedo1
I'm trying to configure a CISCO 2901 Integrated Services Router with a Module VWIC3-1MFT-T1/E1 as a VoIP gateway.
I'd like to know if is it possible, and if there is a especific document in CISCO documentation explaining it.
I have the following escenary:
Inbound calls:
     PSTN (ISDN)  --> CISCO 2901 --> Asterisk (SIP PBX)
Outbound calls
     Asterisk(SIP PBX) --> CISCO 2901 --> PSTN (ISDN)
I have found some documents which explains how to configure a SIP Trunk with registration
http://www.cisco.com/en/US/docs/ios-xml/ios/voice/cube_sipsip/configuration/xe-3s/asr1000/voi-sip-trunk-reg.html
And how to configure the VWIC3 module
http://www.cisco.com/en/US/docs/routers/access/interfaces/software/feature/guide/vd-t1e1_vwic3.html
I'm very new with CISCO and I don't know how to route calls from the module to the Ethernet interface, and if I need to do anything else.
Thanks in advance!
David Pinedo
Presence Technology
Jaime Valencia
For ISDN you need to configure your T1/E1, plenty of material and also references/examples on CSC, a quick search will provide some basic config
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmebasic.html
Search pri-group timeslots to get more examples.
Then you'll need to configure dial-peers for in/out calls, search cisco.com for dial-peer configuration and you'll get all the info you need on how to configure them.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
