Router 880 Serie as a remote PBX
luisamato
Hi ! I have a challenge on my work.
I have a central site with 300 local users and 20 users on 10 remote locations (3 users each one at most), every site with Polycom IP phones.
The central site have a generic IP-PBX and I want to migrate it to Cisco CM in the future (in about 1 year) but firs I have to go ahead with the upgrade of the remote sites routers, and it wil have to be autonomous IP-PBX by now.
- The network is full-IP so i don't need any fxs/fxo/bri card.
- I have an internet conection on each site.
- I will have VPNs on each site (DMVPNs)
- I will connect the routers wifi to the central Wireless-controller-lan
- I need to register each ip-phone to the router and then have a sip trunk to the central site.
Wich Router 800 serie and software do you recommend to me ?
I was investigating and I'm not sure about cisco 881W, Is possible to buy this device with call-manager express software. ( I can't find an voice option without fxs/fxo/bri cards)
Link: https://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78_459542.pdf
Luis
Jaime Valencia
If you want CME, you need to upgrade to at least a 1800 series.
See ISR compatiblity per release here
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thanks Jaime.
Look at this link https://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78_459542.pdf
"● Voice-enabling features:
  ◦ Cisco Unified Communications Manager Express(5 user) which offers innovative key system and small
  private branch exchange (PBX) capabilities for small and medium business customers "
Wich model and feature set I would have to select to enable this features:
Regards.
