08-29-2013 07:10 AM - edited 03-16-2019 07:06 PM
Hello Friends,
Situation Actual (telephony traffic):
RP1 and RP2 ->GW_CS2K (wrong)
How can i carry telephony traffic from RP1 to GW_CS2K and the RP2 to Grupo GTD?
RP1 -> GW_CS2K (ok)
RP2 ->Grupo GTD (ok)
Solved! Go to Solution.
08-29-2013 07:34 AM
Just create separate RG and RLs for the RPs, that's it.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-29-2013 07:34 AM
java
08-29-2013 07:54 AM
To add a tip to what my buddie Jaime suggested (+ 5P J) ,in case of different location you can use Local route group feature.
Here is a nice doc
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmfeat/fslrg.pdf
Carlo
Please rate all helpful posts
"The more you help the more you learn"
