11-13-2019 01:09 AM - edited 12-10-2019 12:38 AM
Hi !
Due to a change of attendant console solution I have (if it is possible) to route a call flow based on calling party number.
Actual call flow :
Fire alarm (call +32 4 1234567) > PSTN > ISR Cisco > Call Manager v12.0 > (old) attendant console Reception [general number]
New call flow :
Fire alarm (call +32 4 1234567) > PSTN > ISR Cisco > Call Manager v12.0 > (new) attendant console Reception [new queue number]
So the goal is to route the calls from fire alarms to a new internal number [queue in attendant console] without change the called party number in each fire alarm. 20 fire alarms involved in 20 differents remote site.
Thanks in advance
Rémi
Solved! Go to Solution.
12-10-2019 12:42 AM
Thanks for your response TONY. That help me to find a new google search way :-)
Procedure that I did :
-0-
Create a Partition named "P_Internal"
Create a Calling Search space "CSS_Internal"
-> Assign "P_Internal" to "CSS_Internal"
-> Assign "P_Internal" to each end user's Directory Number
-1-
Create a Partition named "P_Accept_All"
Create a Calling Search Space named "CSS_SiteName_VGW"
-> Assign "P_Accept_All" to "CSS_SiteName_VGW"
-2-
Create a Partition named "P_route_calls_based_on_calling_party"
Creat a Calling Search Space named "CCS_route_calls_based_on_calling_party"
-> Assign "P_route_calls_based_on_calling_party" to "CCS_route_calls_based_on_calling_party"
/!\ Ensure that Gateway CSS should not have any other Partitions that is being used by Directory Numbers, else the calls will be routed to the Directory Numbers /!\
/!\ So in this exemple "CSS_SiteName_VGW" doesn't have "P_Internal" assigned /!\
-3-
Assign "CSS_SiteName_VGW" in Trunks and/or Gateways for Inboud Calls
-4-
Create a new Translation Pattern
* Translation Pattern : !
* Partition : P_Accept_All
* Description : Accept all calls from Voice Gateway
* Calling search space : "CCS_route_calls_based_on_calling_party"
* Route Next Hop By Calling Party : Check mark
-5-
* Partition : P_route_calls_based_on_calling_party
* Description : Accept unspecified calls
* Calling search space : "CSS_Internal"
* Route Next Hop By Calling Party : Uncheck box
-6-
-> In this exemple, for a specific calling party number (e.g. 0032 123456)
* Translation Pattern : 0032123456
* Description : Specific route for calling 0032123456
* Prefix Digits (Outgoing Calls) : *99
-7-
-> In this exemple, to route call to 92555 only if calling party is 0032123456 and called party is 1111 (where 1111 is e.g. general number)
* Translation Pattern : *99.1111
* Discard Digits : PreDot
* Called Party Transform Mask : 92555
-8-
-> In this exemple, to route via "normal way" all other call
* Translation Pattern : *99.!
* Description : Normal way for specific route
11-13-2019 01:22 AM - edited 11-13-2019 04:35 AM
11-13-2019 04:27 AM - edited 11-13-2019 04:34 AM
11-13-2019 06:53 AM
Are you trying to do this within a CUBE, on CUCM or on CME?
In CUCM you can use the "Route Next Hop By Calling Party Number" option within a translation pattern. It's a bit fiddly but to summarise you create a translation to match the dialled number, then it's CSS looks for matches based on the Calling Number rather than dialled number.
12-10-2019 12:42 AM
-0-
-1-
-2-
-3-
-4-
-5-
-6-
-7-
-8-
