03-28-2012 12:22 PM - edited 03-16-2019 10:21 AM
We are facing some issues while collecting logs from RTMT.
Here is the error I am getting while trying real time logs (Attached is the screen shot)
Also tried collecting few logs however its downloading only SDL logs.
Configuration everything looks fine.
Any help highly appreciated
03-28-2012 04:37 PM
04-12-2012 07:39 AM
This was due to Bug CSCsr64204
here is the details of the same
Symptom:
CCM SDI traces are not written even when traces are enabled
Conditions:
Issue may occur if non-default traces are enabled during upgrade.
Workaround:
None
Further Problem Description:
For confirmation, need the trace configuration settings from the database. Capture the output of following CLI:
run sql select tkservice, filetraceflag from processnodeservice
and send output to IPCBU.
04-08-2013 03:56 AM
For the record, SDI and SDL traces have been combined from CUCM 9.0 onwards. Trying to capture SDI traces will result in the same error.
