06-09-2021 01:30 AM - edited 06-09-2021 01:34 AM
Hello all.
CUCM ver.12.5 SU3. RTMT installed on Windows server 2016 fails to start.
After type IP address of CUCM doesn't get the next window of user and password.
No error received.
Looks like RTMT got stuck.
Any suggestion please ?
Solved! Go to Solution.
06-20-2021 12:32 PM
Friends,
It was SSO issue : once i disabled " use SSO for RTMT" under enterprise parameters RTMT runs correctly ( on the same windows 2016 server of course )
Thank you for your help.
George
06-09-2021 02:39 AM
Hi George
Run RTMT as an administrator then check.
For more detail check below compatibility matrix.
Pls rate if its “Helpful”. If this answered your question please click “Accept as Solution”.
06-09-2021 03:31 AM
Hi Sadav
Run as admin-no difference.
Any more ideas ?
06-09-2021 04:29 AM
Did you downloaded RTMT from same publisher ?
Is there any error during rtmt launching ? Please share if any.
06-09-2021 09:09 AM
Yes, from the same publisher.
No errors, just got stuck
06-09-2021 09:20 PM - edited 06-09-2021 11:06 PM
RTMT supported list of os, Windows server 2016 is not listed so its not supported. I am not sure if the option to run with compatible version is available on server platform, if yes try to run it with any of the version mentioned below and see if it resolves.
06-20-2021 12:32 PM
Friends,
George
