08-17-2016 06:17 AM - edited 03-17-2019 07:51 AM
We would like to monitor administrators who will be accessing the CLI remotely via SSH. Is there a way to send email alerts on unsuccessful and successful logins through RTMT?
08-17-2016 06:27 AM
RTMT has a System Alert for Authentication that you can use.
JB
08-17-2016 06:36 AM
Does this just alert on failed attempts or both failed & successful? We need both.
08-17-2016 06:41 AM
Just the failed attempts depending on what threshold you have set for them.
JB
08-17-2016 06:42 AM
You can also check the same in Audit logs which goes more granular
http://www.netcraftsmen.com/audit-logs-on-cisco-unified-communications-manager-cucm/
JB
08-17-2016 06:57 AM
some more detail that you can go through
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/8_5_1/rtmt/RTMT/rtalsys.html#wp1053071
https://supportforums.cisco.com/discussion/11435716/how-disable-auth-failed-rtmt-alert
http://www.gossamer-threads.com/lists/cisco/voip/117606
https://supportforums.cisco.com/discussion/12044971/rtmt-alert-severitymatch-critical-pamsucceedifsshdauth-error-retrieving
JB
08-17-2016 07:06 AM
Thanks JB
I think SyslogStringMatchFound will work we will test. Thanks for the information.
08-17-2016 07:16 AM
Happy to help,
You can mark the forum as answered if you dont have further questions.
JB
