1182
Highlighted
Beginner
RTP Header Compression under a VPN IPSEC Connection
Is it possible to compress the RTP, UDP and IP headers of a voice packet under a VPN IPSEC connection? These headers are encrypted when IPSEC is set to use ESP.
Best Regards.
2 REPLIES 2
Highlighted
Advisor
I believe these two protocols are incompatible.  cRTP compressess the IP/UDP/RTP headers.  ipsec encrypts these headers.  So, by the time the RTP compression process could be engaged it cannot accomplish it's job successfully.
See this reference:
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/V3PN_SRND/v3p_comp.html#wp1035253
And this netpro doc:
https://supportforums.cisco.com/docs/DOC-2498/version/2
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Highlighted
I suspected that it would not be possible with ESP as the encryption process. I´ve confirmed now. Thanks for the help.
