RTP Ports Reserved
dtom
What does Ports Reserved mean below?
Cube_Top#sh voip rtp connections
VoIP RTP Port Usage Information:
Max Ports Available: 8091, Ports Reserved: 101, Ports in Use: 121
Brandon Buffin
RTP uses even UDP ports between 16384 and 32767. The number of even ports between these numbers is 8192. However 101 ports are reserved and will not be used by RTP. This leaves 8091 ports available for use. Hope this helps.
Brandon
Hi Brandon,
Thanks for the great information above.Very knowledgeable.
VS
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Thanks for the information.  Very useful.
