09-05-2014 07:42 AM - edited 03-17-2019 12:03 AM
Am I wasting my time trying to get CCX Editor to run on Windows 8.1? I've tried running it in compatibility mode with no luck.
09-06-2014 02:14 AM
As per the UCCX 9.0(2) software compatibility matrix, Windows 8 or 8.1 is not supported for Editor
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_9.0%282%29
Same is the case for UCCX 10.5
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_10.5%281%29
Manish
12-06-2014 12:59 PM
Looking forward to 2016 when Windows 8.1 is supported :)
05-22-2015 03:21 AM
Got the ccx editor 10.5 to install on windows 8.1 by installing with compatibilty mode but it wont. i have tried hard....moving on to look for a windows 7 machine.
05-22-2015 06:14 AM
Im running on Windows 8.1.
Compatibility mode for Windows 7
Run this program as Administrator
Edit hosts file
[IP of UCCX Server] FQDN of UCCX Server
05-28-2015 12:11 PM
Didn't work overhere, CCX Editor for UCCX 10.5. Installed fine with compatibility mode for Windows 7 but starting the application did not, UCCX server is in hosts file.
Uninstall is now stuck on Registry entries.
05-28-2015 01:54 PM
Set the application to run in compatibility mode for Windows 7 and Run as Administrator
08-24-2015 01:42 AM
As stated, this didn't work for me, the issue was due to two bugs:
https://tools.cisco.com/bugsearch/bug/CSCuu18876
https://tools.cisco.com/bugsearch/bug/CSCuq83669
Now it works fine (on IP address), DNS still needs to work though to enable repository browsing.
08-24-2015 05:09 AM
Odd. I did a clean install of Windows 10 recently and was able to install CCX Editor by making the host file modification and running the install in compatibility mode for Windows 7 and as Administrator. Once installed, it runs natively. We are running 10.6(1) which may be the key difference here
01-18-2018 11:13 AM
I tried this on a couple of different Windows 10 and Server 2008 machines without success. Was finally successful on Windows 10 by logging in as a local admin of the machine. Changed the properties of the install executable to Windows XP SP3 and run as an admin. Works fine on Windows 10 PC now. By comparison I noticed that the failure seemed to have something to do with the Java folder in the recommended install folder in Program Files (x86)\wfavvid_1061 (java did not install in this folder until I used admin permissions) If that folder is blank, the files did not extract and the installed program does not show up in the installed programs folder.
