SAF Voice service - Simple deployment
santiago
Hi all,
I've spent long days trying to understand the most basically deploment  of the SAF voice service.
(i've guided myself via the next links http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/feature/guide/SAF_FeatureModule.html#wp1194872 and
http://docwiki.cisco.com/wiki/Service_Advertisement_Framework_Support_in_Unified_Communications_-_System_Test_Configuration  )
My lab deploment consists on 2 CME's:
CME A:
dn range 2000-2500
PSTN connection via PRI E1.
CME B:
dn range 3000-3500
No PSTN connection
All i need from an early beggining is to share ( advertise ) the dial-peer of CME A to CME B. Then CME B will be able to dial PSTN numbers.
Also, the hosted-dn ( dn ranges ) to call between them ( CME A and B ) only by advertising their DNs.
From my understandings, i did configured a SAF forwarder, but the adverstising was no successfull.
Any advice will wellcomed.
Ben Rodriguez
I know this is really old but you can simply use dial peers from CME to CME with the remote range from A to B and vice versa. Unless you are setting this up for learning purposes I say keep it simple if it is only two sites.
