same Dial-peer we have 2 legs
Ibrahim Jamil
Level 6
Level 6
Hello guys
why in the same Dial-peer  we have 2 legs , one leg is:
destination-pattern 14087771..
while the 2nd leg its for incoming called-number 14087771...  for the same string
thanks
Chris Deren
Every call has 2 call legs: inbound and outbound, and it's possible to match same dial-peer for both legs depending on the configuration, so there is nothing unusual about it. Check out this doc for detailed explanation on dial-peer matching:
https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/14074-in-dial-peer-match.html
thanks bro
