697
Beginner
SBC SIP INVITE Message - From Header Field does not contain SBC's Signalling IP
For some reason SBC does send within INVITE message the IP Address of SIP Client [private IP] instead of
SBC signalling IP.
Example:
Client SIP Host IP: 192.168.58.1
SBC Outside SIP Signalling IP: 199.150.1.1
Adjacency Peer IP: 166.34.245.231
Via: SIP/2.0/UDP 1199.150.1.1
From: “3660110” <sip:3660110@192.168.58.1>;tag=199.150.1.1+1+56c....
To: <sip:1201123456987@166.34.245.231;user=phone;phone-context=unknow
Desired SIP Invite From Field
From: “3660110” <sip:3660110@199.150.1.1>;tag=199.150.1.1+1+56c....
djacency sip eExampleSIP
    nat force-off
    method-profile inbound custom-method-profile
    method-profile outbound custom-method-profile
    error-profile outbound max-call-per-adjacency
    hunting-trigger 404 500 503
    signaling-address ipv4 199.150.1.1
    statistics method summary
    signaling-port 5060
    remote-address ipv4 166.34.245.231 255.255.255.255
    signaling-peer 166.34.245.231
    header-name From passthrough
    ping-enable
    realm outside
    attach
1 ACCEPTED SOLUTION
Beginner
Re: SBC SIP INVITE Message - From Header Field does not contain SBC's Signalling IP
Correct, removing this parameter fixed it.
Thanks.
7 REPLIES 7
VIP Advisor
Put this command in your outgoing dialpeer
voice-class sip requri-passing
Beginner
Hello Mohammed,
Thank you for response. We are not using dial-peers.
Therefore, I am not able to apply it.
I try to explain the situation:
SIP Client  is sending call through SBC to another carrier.
For call identification reasons, we had to apply a customized method profile for this adjacency.
I am wondering, if this could be the cause for the SIP INVITE From Field issue, where instead of the SBC's outside signalling IP, the SIP Server's private IP is passed.
Please see example, the FROM field should contain SBC's Signalling IP and not any information about the
SIP Client Private IP, which is initiating the calls.
Currently:
Desired:
From: sip:+12125551212@<SBC Outside Signalling IP>;tag=887s
 adjacency sip eExample
    nat force-off
    signaling-address ipv4 <SBC Outside Signalling IP>
    signaling-port 5060
    remote-address ipv4 <Outside Signalling IP of adjacency peer/Carrier>
    signaling-peer <Outside Signalling IP of adjacency peer/Carrier>
    ping-enable
    realm outside
    attach
   sip header-profile custom-header-profile
    header From entry 1
     action as-profile
    header X-CardEasy-CID entry 1
     action pass
    header Remote-Party-ID entry 1
     action pass
    header P-Asserted-Identity entry 1
     action pass
   sip method-profile custom-method-profile
    method INVITE
     action as-profile
VIP Mentor
Could this be because you have this enabled?
"header-name From passthrough"
By default the SBC should include its own IP in the host portion of the From header.
Please rate all useful posts
VIP Advisor
Header name from passthrough would be causing it
Beginner
Thanks.
VIP Mentor
Glad to hear that but you didn't mark my answer as the resolution. Looks like you marked your post as the solution
Highlighted
Beginner
problems with phone getting busy tone dialing out and people calling can you help me
So Ive been tasked to help with a cisco issue I have access to the call manager by vpn and the gateway the phones can dial ext to ext but when calling out or one is calling in you get a busy signal I need this issue fixed by tomorrow I been reading your post and was wondering if you can help me we can do a screen share if possible.
Content for Community-Ad
August's Community Spotlight Awards
