02-04-2011 07:01 AM - edited 03-16-2019 03:16 AM
I have configure a 2811 and my CCM 7 as per the following DOC
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t14/feature/guide/gtstcapp.html
But I cannot get the port to register.
Router Config as follow
SKIGW22904C42B8#sh run
Building configuration...
Current configuration : 2223 bytes
version 12.4
hostname SKIGW22904C42B8
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
logging message-counter syslog
no aaa new-model
network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
no ipv6 cef
stcapp timer roh 30
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp feature speed-dial
isdn switch-type basic-net3
voice-card 0
username spec privilege 15 secret 5 archive
log config
hidekeys
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
interface Service-Engine0/0
no ip address
shutdown
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI0/2/0
no ip address
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
isdn skipsend-idverify
line-power
interface BRI0/2/1
no ip address
isdn point-to-point-setup
ip default-gateway 192.168.1.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip http server
no ip http secure-server
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
timeouts initial 60
timeouts interdigit 60
timeouts ringing infinity
voice-port 0/2/1
ccm-manager config server 172.16.74.10
ccm-manager config dialpeer-prefix 888
ccm-manager sccp local FastEthernet0/0
ccm-manager sccp
mgcp fax t38 ecm
sccp ccm 172.16.74.10 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer voice 888020 pots
service stcapp
port 0/2/0
line con 0
line aux 0
line 194
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
login local
line vty 5 17
login local
scheduler allocate 20000 1000
end
SKIGW22904C42B8#
Total Devices: 1
Total Calls in Progress: 0
Total Call Legs in Use: 0
Port Device Device Call Dev Directory Dev
Identifier Name State State Type Number Cntl
0/2/0.1 BR22904C42B8100 OOS UNREGISTERED BRI Not Avail UNKN
02-07-2011 03:30 AM
Can any one help?
