SCCP Analog endpoints having call transfer issue.
karthikeyanm
One of my branch office have 2901 router with four FXS connection. I have configured MGCP gateway first with my CUCMBE, but as I need call supplementary features such as call pickup and call back, I have converted those endpoints as SCCP. But now the call transfer stopped working.
Below is the scenario.
Analog 1 calling Analog 2.
Analog 2 transfer to Analog 3 using hookflash transfer.
Analog 2 and Analog 3 both gets disconnected.
Analog 1 still in connected. (Silence. No MOH either)
I have changed hookflash duration too.
Pl help me on this issue.
-HTH Karthik.
Rob Huffman
Hi Rob,
Thanks for the document. I have done basic configuration with this document only. I tried the feature mode too. I got it working after I changed the device profile to Non SRST profile. Wierd. There is an issue with SRST it seems. I am checking out it. Update you as soon as I found the soln. If you have any ideas pl share it.
-HTH Karthik.
Hi Rob,
The following is the configuration in the 2901 IOS gw. I have enabled feature mode but not working. What could be the problem. As soon as the hookflash is pressed it disconnecting immediately.
voice-port 0/1/3
timeouts ringing infinity
timing hookflash-in 300 0
caller-id enable
router# sh run | sec stcapp
stcapp ccm-group 1
stcapp
stcapp feature access-code
prefix #
pickup local 4
pickup group 5
meetme-conference 3
forward-to-voicemail 9
stcapp feature callback
activation-key #7
stcapp supplementary-services
port 0/1/0
  hold-resume
  fallback-dn 106
port 0/1/1
  hold-resume
  fallback-dn 104
port 0/1/2
  hold-resume
  fallback-dn 103
port 0/1/3
  hold-resume
  fallback-dn 102
stcapp call-control mode feature
hangup-last-active-call *8
transfer *7
conference *5
drop-last-conferee *6
toggle-between-two-calls *4
-HTH Karthik.
