303
Highlighted
Beginner
SCCP extension internal call to internal SIP extension go to public ip
PROBLEM
1. I can call from SIP (ext 812 Zoiper) to SCCP (Cisco Soft Phone ext 803) but not vice versa
From debug ccsip message shown, if I call from ext 803 SCCP to ext 812 SIP. It goes to external ip address.
It should go to internal ip instead.
How to fix that?
thanks
INFO:
-2811
-7912
-Zoiper
-Cisco Soft Phone
#debug ccsip message
#term mon
Sep  4 04:26:29.716: //136/E90D33C980FD/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:812@118.136.227.177:43123 SIP/2.0
Via: SIP/2.0/UDP 10.0.10.206:5060;branch=z9hG4bK7921B9
Remote-Party-ID: <sip:803@10.0.10.206>;party=calling;screen=no;privacy=off
To: <sip:812@118.136.227.177>
Date: Fri, 04 Sep 2015 04:26:29 GMT
Call-ID: E99109FF-51F311E5-8102AC05-BB277C0A@10.0.10.206
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 3909956553-1374884325-2164108293-3139927050
User-Agent: Cisco-SIPGateway/IOS-12.x
#sh run
version 15.1
voice service voip
ip address trusted list
  ipv4 192.170.159.194 255.255.255.255
  ipv4 54.251.255.196 255.255.255.255
  ipv4 10.0.10.0 255.255.255.0
  ipv4 10.0.20.0 255.255.255.0
  ipv4 10.0.30.0 255.255.255.0
  ipv4 10.0.40.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice register global
mode cme
source-address 10.0.10.206 port 5060
max-dn 144
max-pool 35
tftp-path flash:
file text
create profile sync 0004537381553201
voice register dn  1
number 812
name 812
voice register pool  1
id mac 0000.0000.0812
number 1 dn 1
username 812 password 123
codec g711ulaw
no vad
voice translation-rule 9
rule 1 /\(^9\)/ //
voice translation-rule 628
rule 1 /^628/ /08/
voice translation-rule 9628
rule 1 /^9/ //
rule 2 /^\(.+62\)/ /0/
voice translation-profile 9
translate called 9
voice translation-profile 9628
translate called 9628
voice-card 0
license udi pid CISCO2811 sn FTX0918A0PF
archive
log config
  hidekeys
username admin privilege 15 secret 5 $1$XeEC$YORXhK8ZUtFjwabnYoHpS0
username cisco secret 5 $1$nFBH$Q6uWzeOmiu20v0UFFhqzY1
redundancy
no ip ftp passive
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
ip address 10.0.10.206 255.255.255.0
ip pim sparse-dense-mode
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.0.31.1 255.255.255.0
ip nat inside
duplex auto
speed auto
router eigrp 1
network 1.1.1.1 0.0.0.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http secure-port 8443
ip http timeout-policy idle 60 life 86400 requests 10000
ip pim rp-address 1.1.1.1
ip nat inside source list 101 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 10.0.10.1
ip access-list standard blockedhost
deny   46.165.249.4
deny   118.136.227.177
permit any
tftp-server flash:CP7912080004SCCP080108A.sbin alias CP7912080004SCCP080108A.sbin
control-plane
call threshold global cpu-avg low 68 high 75
call threshold global total-mem low 75 high 85
ccm-manager music-on-hold
mgcp fax t38 ecm
mgcp profile default
dial-peer voice 1 voip
description Outgoing SIP DIDLogic
translation-profile outgoing 9
destination-pattern [+,9]1[2-9]..[2-9]......
session protocol sipv2
session target dns:sip.sg.didlogic.net
voice-class codec 1
voice-class sip bind control source-interface FastEthernet0/0
voice-class sip bind media source-interface FastEthernet0/0
dtmf-relay sip-notify
dial-peer voice 10 voip
answer-address 801
destination-pattern 14159172008
voice-class codec 1
dial-peer voice 20 voip
answer-address 801
destination-pattern 85258010007
session target dns:sip1.hoiio.com
voice-class codec 1
dial-peer voice 6 voip
description Outgoing SIP Hoiio
destination-pattern [+,9]852........
voice-class codec 1
dial-peer voice 11 voip
description Outgoing SIP Planet
translation-profile outgoing 9628
destination-pattern [+628,908]........T
session target ipv4:10.0.10.87
codec g711ulaw
dial-peer voice 30 voip
num-exp 85258010007 801
num-exp 14159172008 801
num-exp 081298998288 801
sip-ua
credentials username 1001 password 7 025756085F5123 realm 10.0.10.87
credentials username 08845 password 7 01232617481C561123 realm sip.sg.didlogic.net
credentials username sip7228256 password 7 044A04030475786A254809033B2123 realm sip1.hoiio.com
authentication username 08845 password 7 15222B1F173D7B3123 realm sip.sg.didlogic.net
authentication username sip7228256 password 7 06170024471A3D3D29461E1F252123 realm sip1.hoiio.com
authentication username 1001 password 7 00554155500123 realm 10.0.10.87
registrar 1 dns:sip.sg.didlogic.net expires 3600
registrar 2 dns:sip1.hoiio.com expires 3600
registrar 3 ipv4:10.0.10.87 expires 3600
sip-server dns:sip.didlogic.net
telephony-service
no auto-reg-ephone
max-ephones 35
max-dn 144
ip source-address 10.0.10.206 port 2000
max-redirect 5
cnf-file location flash:
date-format dd-mm-yy
max-conferences 8 gain -6
moh flash:/Wave.au
multicast moh 239.1.1.1 port 2000 route 10.0.10.1
web admin system name admin secret 5 $1$JGDo$afA54af/90u3S4gnt0s123
transfer-system full-consult
create cnf-files version-stamp 7960 Sep 04 2015 02:04:12
ephone-dn  1  dual-line
number 801 no-reg both
label Operator (x801)
name user delapannolsatu
ephone-dn  2  dual-line
number 802 no-reg both
label Sales (x802)
ephone-dn  3  dual-line
number 803 no-reg both
label CS (x803)
mobility
snr +6287809777430 delay 10 timeout 30
ephone-dn  4
number 888 no-reg both
name POC-Paging
paging ip 239.1.1.2 port 2000
ephone  1
device-security-mode none
mac-address 000B.BE3B.9E9C
username "u801" password 123
paging-dn 4
type 7912
button  1:1
ephone  2
mac-address 0012.0127.A14A
paging-dn 4
type 7912
button  1:2
ephone  3
mac-address E0DB.55A9.B3D5
paging-dn 4
type CIPC
button  1:3
1 ACCEPTED SOLUTION
Highlighted
Please check if STUN (or any other NAT option) is enabled in Zoiper or not. Ensure it's disabled and share the REGISTER meesage.
5 REPLIES 5
Highlighted
Beginner
I got different behaviour if I use X-Lite.
Here if using Zoiper. Its contact is DIDLogic ip
#sh sip-ua status registrar
Line          destination      expires(sec)  contact
transport     call-id
              peer
812           10.0.10.112      263           118.137.204.179
TCP           bhUmyW41HflFVs8pXfeCag..
              40001
Here if using X-Lite.
Its contact is X-Lite ip
RTR2811a#sh sip-ua status registrar
transport     call-id
              peer
812           10.0.10.112      292           10.0.10.112
TCP           76589NDIwOWIwOGNmMTgwYTZhYWFhYzAwNTUwZTVlZGNkY
              40001
Tried both application but still can't call SIP from SCCP 7912
thanks
Highlighted
Highlighted
SIP CLIENT SETTINGS:
Zoiper
Settings/Preferences/Accounts/General
Domain: 10.0.10.206
Username: 812
Password:
Caller ID Name: 812
Auth. username: 812
tick Use outbound proxy
Outbound proxy: 10.0.10.206
Settings/Preferences/Accounts/Extra
tick Register on startup
Settings/Preferences/Accounts/Codec
Selected codecs: u-law first
Settings/Preferences/Accounts/Advanced
Use DTMF RFC-2833
Use UDP transport
TLS with no SRTP
Don't use STUN
CSipSimple
Account name: Cisco
User: 812
Server: 10.0.10.206
Password:
I can't make X-Lite working, but Zoiper working all the time
Highlighted
VIP Advisor
Check you nat statements. Try to exclude voip subnets from NAT
Highlighted
isp modem (dynamic ip)-> my TPLink -> cme ip 10.0.10.206
I am not really using NAT in the router.
-CME f0/0 10.0.10.206
-7912, Cisco Soft phone, Zoiper and X-Lite are in 10.0.10.x
So both CME and client in the same subnet.
Just for test in my POC, I am using the same subnet
