06-26-2014 03:03 PM - edited 03-16-2019 11:13 PM
We have both sccp and sip phones with shared lines. When on SRST only the sccp shared line will ring for an inbound call but not the sip shared line. Is there a way to make this work or is this not supported?
Manish
06-26-2014 04:29 PM
Can you post your config?
Yosh
06-27-2014 07:29 AM
Here is the pertinent config...
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol cisco
sip
registrar server
midcall-signaling passthru
voice register global
max-dn 144
max-pool 42
dialplan-pattern 1 312555.... extension-length 6 extension-pattern 21....
application app.sip
voice register pool 1
id network 10.109.0.0 mask 255.255.0.0
dtmf-relay rtp-nte
call-forward b2bua busy 214005
call-forward b2bua noan 214005 timeout 10
codec g711ulaw
no vad
voice-card 0
application
global
service alternate default
dial-peer voice 1 pots
destination-pattern 91[2-9]..[2-9]......
port 0/0/0:23
forward-digits 11
dial-peer voice 2 pots
destination-pattern 9011T
port 0/0/0:23
prefix 011
dial-peer voice 3 pots
destination-pattern 9[2-9]11
port 0/0/0:23
forward-digits 3
dial-peer voice 100 pots
incoming called-number 312555....
direct-inward-dial
port 0/0/0:23
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.9.176.135 port 2000
max-ephones 42
max-dn 144
transfer-pattern .T
voicemail 214005
alias 1 0 to 214005
call-forward busy 214005
call-forward noan 214005 timeout 15
06-26-2014 08:51 PM
At a bare minimum, you need to make sure your gateway is configured to function as a SIP Registrar Server for the phones. You can achieve this under the 'voice service voip' section.
>enable
#conf t
#(conf) voice service voip
#(conf-voi-srv-voip) sip
#(conf-voi-srv-voip-sip) registrar server [expires [max sec] [min sec]]
If you already have this, then throw up your config so we can break it down and troubleshoot.
-Tony
05-05-2016 10:01 PM
Hi Manish.
Did you ever get to the bottom of this? I have the same problem with a 9971 and a 7925. In SRST they both register with the shared DN, but if you call the DN, one time the 9971 will only alert and the next time only the 7925 will alert?
05-06-2016 12:04 AM
Hi Tim,
As per the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmebasic.html#pgfId-1081127
To configure a mixed shared line between Cisco Unified SIP IP and Cisco Unified SCCP IP phones, perform the following steps.
Manish
05-06-2016 12:18 AM
Thanks Manish.
I think I am safe in assuming I need to be using CME as SRST and not CallManager fallback like I am now for this to work?
05-06-2016 12:20 AM
Apologies, just read the last line of the restrictions:-
