09-14-2015 09:39 PM - edited 03-17-2019 04:18 AM
HW/SW Info:
-CUCM 10.5
ip 10.0.10.77
gw 10.0.10.1
-7912 with ext 1001 and 1002
-X-Lite Softphone with ext 1011
-Cisco Softphone ext 1003
PROBLEM:
1. I can't call from any internal SCCP ext (1001-1003) to SIP extension 1011.
In other word is SCCP to SIP call problem.
I don't have problem call between internal SCCP to SCCP extension or
between SIP to SCCP extension.
Attached trace file call from SCCP ext 1003 to SIP ext 1011
Solved! Go to Solution.
09-15-2015 06:43 AM
Those problems are ALWAYS CSS and partitions, FYI, it's a very poor design to NOT use partitions, you'll soon find a lot of limitations by doing that (which will then require to change a lot of things). I STRONGLY suggest you review the dial plan chapter under the SRND to understand how a dial plan works.
09-15-2015 01:54 AM
My mistake
In Call Routing/Directory Number.
I need to set None to every extension Partition
Once I did that, I can call SIP phone from SCCP
thanks
09-15-2015 06:43 AM
09-15-2015 06:49 PM
Currently I set
Call Routing/Directory Number/Extension/Partition: None
User Management/End User/user/SUBSCRIBE Calling Search Space: POC-HQ-CSS-EMPLOYEES
So far so good.
My question now:
1. which will be the winner if I mistakenly set
Call Routing/Directory Number/Extension/Partition: didn't allow International Call
User Management/End User/user/SUBSCRIBE Calling Search Space: allow International Call
2. which one will win if I have conflicting CSS in
Device/Phone/phone/Calling Search Space
Call Routing/Directory Number/Extension/Calling Search Space:
thanks
09-15-2015 09:34 PM
OK, the SUBSCRIBE CSS is NOT used for call routing, and the partitions does NOT determine who/what you can call.
So, question one, does not even makes sense, as you're asking things that do not even work together.
Q2, is answered in the SRND, I strongly suggest you to read the dial plan chapter from the SRND before further questions..
09-15-2015 10:15 PM
Nawir,
1-you dont have to use the subscribe CSS for phone calls.
Generally, the 'winner' will always be the CSS that you configured on the extension of the phone (if there is a tie)
I would strongly suggest you put the extensions/DNs in a partition.
I you are not sure about your dial plan, you can go to serviceability>Tools>Dialed number analyzer and simulate the calling and called number, this will tell you exactly which partitions/CSS get used to route the call and it makes troubleshooting so much easier
