script its-CISCO.2.0.3.0.tcl
kamil_folga
Hello!
I use a script its-CISCO.2.0.3.0.tcl for AA services in CME 10.5. Script config:
application
 service aa flash:its-CISCO.2.0.3.0.tcl
  paramspace english index 0
  paramspace english language en
  param operator 21
  paramspace english location flash:
  paramspace english prefix en
  param aa-pilot 4999
dial-peer voice 4999 voip
service aa
destination-pattern 4999
session target ipv4:172.16.1.1
incoming called-number 4999
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
voice-port 0/2/0
 connection plar opx 4999
 impedance complex1
 caller-id enable
Script works, but I do not see caller-id on destination phone. I see on phone caller-id 4999. Also when an external line attempts to connect through the system, but the external POTS phone disconnects before the IP phone user picks up – the IP phone will ring FOREVER – until the IP phone is taken off-hook.
What can cause the problem?
Kamil
kamil_folga
When I remove "dial-peer voice 4999 voip" and set:
dial-peer voice 301 pots
 service aa
 incoming called-number .%
 direct-inward-dial
 port 0/2/0
I have "Unknown number".
Whats wrong?
Kamil
SOLVED??!!
What did you done that solved that.
Do you know if this script works in SRST mode with sccp and sip ip phones?
Thanks.
